Just got it in this morning from GMpartsdirect.com - with shipping 15 less than retail MSRP. Nice quality - very tight weave on the carpet like Berber and the insignia looks stitched on, and not just heat attached...good detail on logo:
Well, admittedly I'm a dolt, but I was just all over the GMpartsdirect.com website and could not find where the 2014 accessories are??? Can anyone help me put??
Chev did not look too closely when they made the cargo accessory mat. They did not create slits so the front cargo shade can be mounted. A simple razor blade slit will allow the d rings to punch thru so the shade can be used. Just an FYI...
Hey glen e, did the shade come with the car automatically, or do we have to order it separately? Also, what is the difference between upper shade and lower shade? Thanks!
Here is a shot of the upper and lower shade in RedHot. When the trunk is closed you do not see it from the inside and it in no way interferes with rear vision. :
Glen,
There's another thread about cargo mats not fitting correctly because the rings to secure the shade are covered by the mat. GM is sending out letters letting people know they are getting a free, corrected product. Is the Stingray cargo mat (part # 23469813) what they are talking about? I plan to order one if it will fit correctly. My LRG Stingray was built on Feb. 11. Should have it soon.
I understand your simple fix would be to use a razor and make cut to allow the rings to pop through. Good idea.
Yes, the other thread is GM'S admission of the mistake and their correction. Ok with me, I like the slit better actually, as it looks more efficient and hides part of the ring.
We’re a forum community dedicated the Corvette Stingray. Come join the discussion on performance modifications, accessories, purchasing, maintenance and more!
