Tried both keys and neither will start the car using the remote button. Any ideas?
Thanks,
Randy
Thanks,
Randy
Remote start on auto trans only, I believe. With car in Park, press door lock button then press remote start button. Works fine on mine.Tried both keys and neither will start the car using the remote button. Any ideas?
Thanks,
Randy
Yup. Just tried mine for the first time in 6 months and it works fine.Remote start on auto trans only, I believe. With car in Park, press door lock button then press remote start button. Works fine on mine.
Are you holding the start button down until the engine starts? It's not just a momentary push.Have auto transmission. Have hit the lock button and remote start a dozen times. Won't work.
When you get in the car and the car is running, the start/stop button is red. Put your foot on the brake and press the start/stop button. The button will now be green.After starting remotely and getting into the vehicle, what is the process to drive off? Seems to require stopping and restarting manually, which couldn't be the way it was intended. Gear shift is locked out of drive when getting in.
