2015 ZO6. Coupe Problem with roof creaking/rattle. When vehicle went in for 1st service 3+ years ago fixed. It is now making noise again.
Often removing the roof panel, cleaning the gasket all the way around and applying a thin coating of dialectrical lube does the trick.
Reactions: ghwinokur and 21017
Had the same issue on my 2017 and remedied the problem by installing O-Rings to the roof posts!
Bought the O-Rings at Lowe's in the Plumbing Section!
The o-rings worked great on my roof.
Reactions: Ateupjoe
That happened with my 14 C7. I wrapped some electrical tape around the pins and it’s been quiet ever since. The dealers have a fix for it.
My 2015 Z-51 had that terrible creaking noise when it warmed up outside. I tried the grease, tried the O-rings, tried tightening and loosening the pins. finally gave in and had the GM Chevy solution done, they replaced the alignment pins with a pin that was coated, and replaced the latches... Finally quiet, like it should have been from the factory., there is a factory bulletin on it.
They changed to pins later in 2015. That is what is used in the update.
My 2015 (April 2015 delivery) started the popping and cracking this past summer. I have cleaned and greased each year. Can you point me to the factory bulletin?
