Sold here by RPI and other vendors, I received it today. I wanted it as I make a few trips a year out of town, don't want XPEL and don't like how the GM one mounts. So here's the good and bad:
the good:
I think it looks great. It mounts simply by replacing front wheel inner fender torx bolts and snapping it on. Stretch it across and pull it down over the front. Literally it has enuf stretch that it looks like it does not need bolt snaps underneath but comes with two that will do the job in place of the stock 7MM's there. Plenty of stretch even over the splitter. Then open the hood and loop it on the edges of the frame and you're done. All of a 20 min install and about a 60 sec on and off and off.
The bad: pretty minor, as suspected a curb alert will not work thru it, and the two snap bolts they supply for underneath are not long enuf to go thru the splitter and undercladding. Also the loops that go on the frame are rubbing under stress against a raw sheet metal edge so long term it could tear there, a little duct tape or some other cladding on the edge should keep it from abrading.
enjoy - I'm keeping it..Please no questions on if a rock will get thru, will it scratch the front or others as I don't know....
the good:
