Are you looking for that custom LED touch to add to your C7 Corvette Stingray? Look no further than Southern Car Parts for all of your LED needs :thumbs:
C7 Corvette LED License Plate Set - $14.00
available here: C7 Corvette Stingray LED License Plate bulbs, C7 Corvette LED bulbs, C7 Corvette
Looking for a great way to brighten up your license plate area on your new C7 Corvette Stingray? These C7 Corvette LED License plate bulbs replace those stock halogen bulbs that GM includes from the factory. You can choose from Red, White or Blue.
Very easy to install, simply pull down the bulb housing and replace. Installs in 5 minutes.
Available colors: Red, White, Blue
C7 Corvette LED Rear Exhaust Filler Area - $28.95
available here: C7 Corvette LED Rear Exhaust Filler Area Lighting Kit
Introducing our new C7 Corvette Stingray Exhaust Led lighting kit. Choose between our BRIGHT or SUPERBRIGHT kits. Kit comes with a 16" waterproof LED strip with 24 leds and wiring to tap into the rear side marker lights so it will come on with the lights. Installation take about 1 hr.
Available colors: amber, green, yellow, orange, white, blue, red
C7 Corvette LED Rear Bumper Fascia Kit - starting at $94.95
available here: C7 Corvette LED Rear Fascia Lighting Kit
Introducing our new C7 Corvette rear fascia led lighting kit designed specifically for the C7 Corvette Stingray. This kit is pre-wired to tap into the rear side markers so they will come on when the marker or headlights are on. They can also be wired into our C7 Corvette fender cove and hood scoop kit if you want to control them wirelessly. Purchase our under car wiring kit if you want to wire them to the cove lighting kit. This is a great option for car shows or cruise in's. This kit will illuminate the vents on each side of the taillights and the vents on the lower rear fascia and also includes a exhaust area lighting kit. Select from our many colors but RED or Yellow/Amber may be the only legal colors. Check the laws in your state. If you want to use other colors we recommend using our fender cove remote controlled kits to run this kit so you can turn them on or off when wanted.
This kit includes:
*(2) waterproof led strips per side with a total of 54 superbright leds.
*(1) exhaust led kit with 24 bright waterproof leds.
*Mounting hardware.
*Instructions
Available colors: red, green, blue, yellow, orange, amber, white
C7 Corvette LED Hood Vent and Side Vent Kit - $128.00
available here: http://www.southerncarparts.com/corvette-led-hood-vent-and-side-vent-kit-p-5876.html
Introducing our new C7 Corvette fender cove and hood vent led lighting kit. This kit is designed specifically for the C7. Kit comes complete with only 2 easy connections to make under the hood. This remote control switches the leds on or off only. Please check out our 4 function remote control kit also.
The kit includes the following:
*(2) 18" waterproof led strips w/27 leds on each side for the fender cove.
*(1) 28" waterproof led strip w/42 leds for the hood vent.
*Complete wiring harness.
*Our kit has extra leads on the fender cove wiring so you can wire our rear facia kits to work with the remote instead of coming on with the lights. You can order this optional wiring kit on the rear facia led kit page.
*Installation hardware.
Available colors: red, green, blue, yellow, orange, white, amber
C7 Corvette Exhaust Filler Panel w/RED LED - $119.95
available here: http://www.southerncarparts.com/corvette-exhaust-filler-panel-wred-led-p-5809.html
Dress up your 2014+ C7 Corvette Stingray with our Brushed - Stainless Steel, Stock C7 Exhaust Filler Panel - Illuminated with Red LED kit. These trim pieces are designed to fit all 2014+ Corvettes around the stock exhaust tips and add a clean stylish look to your Corvette exterior.
NOTE: Fits C7 Corvette with NPP Dual-Mode exhaust system.
C7 Corvette LED Fuel Rail Covers Lighting Kit - $124.00
available here: C7 Corvette LED Fuel Rail Lighting Kit
Dress up your 2014 C7 Corvette Stingray Engine bay with our Fuel Rail Cover Lighting Kit. These pieces are designed to fit all 2014 C7 Corvettes on the under side of the fuel rail covers and add a clean stylish look to your Corvette engine bay.
Available in Blue, Green, Red, White and Yellow.
C7 Corvette LED Ambient Footwell Lighting Kit - starting at $31.95
available here: C7 Corvette Stingray LED Footwell Lighting Kit
Introducing our new LED footwell lighting kit for the new C7 Corvette Stingray. This kit will light up the entire footwell area not just a small area like the factory light. This C7 Corvette Kit includes led strips with 15 BRIGHT leds per side. Covers drivers and passenger footwell and retains the "theater" effect of the factory interior lights. With all our available colors other corvette owners will be checking your car out! Installation takes 1/2 hour and instructions are provided.
C7 Corvette LED Hatch Strips Lighting - Trunk Compartment - $27.99
available here: C7 Corvette Hatch LED Strip Trunk Compartment Lighting
Looking for a great way to brighten up your cargo area on your new C7 Corvette? These LED strip lighting kits are designed to piggyback onto the factory trunk/hatch lights. The will only come on when the interior trunk lights come on. You can choose from Red, White or Blue.
Each C7 LED trunk lighting kit comes with 3M adhesive pre-applied tot he backing for quick and easy installation. Installs in 15 minutes.
Available colors: red, white, blue
This kit includes:
*Mounting hardware.
*Instructions
