Selecting Drive Modes
1 reading
5.8K views 53 replies 16 participants last post by  jay.fishman
#1 ·
Can you change the drive mode while the corvette is moving? For example, can you change from Economy mode to Weather or from Tour to Sport? What is the difference in the feel of the car between Sport and Track?
#3 ·
Short answer: yes, no problem. This table should help:
#4 ·
To answer your question. You can switch modes any time.
The difference between Sport and Track depends on what car you have.
If you have Magnetic ride the Track mode is stiffer than sport and that is stiffer than Tour.
The steering is similar. Tour -Easy, Sport-Stiffer and Track-Heavy
Exhaust changes if you have that option. Quite, nice and sort of loud
You can lock the steering, Ride and sound in anyone of the modes and it will still let the other modes change with the knob.
In my case I always locked the steering in sport along with the sound. I let the mag ride change with the mode switch. Most times I drove in Sport but on rough roads use tour. I only used Track mode on very smooth roads or at the track.
Hope this helps
#28 ·
Internet myth. The very early GM AFM systems had issues, but that's not been the case for many years. Yes, the AFM lifters fail rarely. So do any other hydraulic lifters. There are literally millions of GM small block V8s with AFM lifter in them. If there were a real problem, you'd be hearing about it every day.
Reactions: alberholden
#19 ·
To keep things in perspective, there were 189,507 C7s produced and no recall was every required by NHTSA or voluntarily by GM because of the cylinder deactivation technology in the respective engines. Certainly there are individuals who have had valve failures, but relative to the number of C7s it has not risen to a point of systemic concern about Active Fuel Management (AFM) on our cars.
owns 2018 Corvette C7 2LT
#53 ·
#54 · (Edited by Moderator)
As I write this, my 2015 C7 is in the shop getting Corsa exhaust, AFE cold air intake, and a tune. I've told them to tune out the AFM, which I hate. About a year ago, I heard a rattling noise and couldn't figure where it was coming from. I decided to install one of the inexpensive AFM disablers you plug into the OBD port simply to eliminate the AFM function, which it did. Low and behold, the rattling stopped. I'm guessing it was the lifters. Can't convince me that this AFM nonsense does anything but make a mess of your engine.
