Gary, you and I have remarkably similar situations and issues. I. too have a Long Beach Red C7 that parks under or on top of a lift, and your lift looks a lot like my Pro Park 8S. I, too, have a low ceiling in my garage, but 10' instead of your 9.5'. I, too, had a battery issue--my 2016 Z06 was four years old last April 4, when I took it off the lift from its winter nap. It is always on a battery tender when up and had never failed to start, but at the 4 year mark it cranked very slowly but fortunately finally started. I immediately made an appointment to get a new battery from my Chevy dealer. Batteries, especialy the 3 year warranty OEM ones, typically only last 3-4 years, so I caught mine in time. I would suggest that you make a preemptive strike and replace it before it fails, thereby avoiding having to answer your questions about what to do. I followed my own advice on my home furnace and water heater a few years ago and will do so with the A/C unit this April. None had failed but were (are) near the end of their 15 year service lives. I know that if any were to fail, they would only do so at the worst possible time (Murphy). So that is my philosophy.
Now as to your lift and garage. When I first installed the lift I could only park my cars on top backward because of where the door ended. Tricky getting them centered on the ramps. What I did was raise the tracks to within 6" or less of the ceiling. This did two things. It got them higher up so there was more room underneath, and it reduced how far the door came across the ceiling when up. I can now park either car (the other is a BMW 5 series sedan) pulled in forward. I also replaced the center mounted garage door opener with a Liftmaster 3800, a jackshaft opener that is located in the corner of the garage instead of the center of the ceiling. Just in case, to maximize vertical space, I cut the horizontal brace on the door top half way across and replaced it with an "L" channel and padded it with some 1/4" rubber I had lying around. There are lots of pictures of my garage in my Albums section if you want to see them and I would be glad to answer any questions about my installation if it might help. While I, too, can't open my hatch while the Vette is under the lift, at least I can get both cars up on top when I need to and I would bet you could too with a few changes especially with a little Triumph as the other car. I have a 4' tall car and a 5' tall car and have no problems doing so.Good luck--Bob
