Stahlbus oil drain valves are installed in place of conventional oil drain plugs. Once installed the valves simplify the procedure for changing oil in your car. The quick disconnect drain hose connector snaps into place opening the valve to drain the oil. When the drain hose connector is removed the valve automatically closes. Each Stahlbus oil drain valve includes a high-strength steel valve body, copper sealing washer, anodized aluminum safety cap, quick disconnect hose connector, 40 cm Silicone drain hose, and instructions.
Unlike competitive oil drain valves, Stahlbus oil drain valves do not have a lever-operated ball valve. The valve is opened when a quick disconnect hose connector is attached to the valve. The absence of a lever allows for a much smaller valve design compared to competing products. The Stahlbus drain valve is just slightly larger than the standard oil drain plug. The smaller symmetrical shape of the Stahlbus valve allows it to be installed without an additional adapter frequently required by the more bulky lever-operated valves.
Corvettes require the M12x1.75 thread size.
Stahlbus Oil Drain Valves - How it works.
Reverse Logic Limited Store - Oil Drain Valves
