1 - 13 of 13 Posts
I use Adams Leather and Interior Cleaner. Seems to work well.
I use AmmoNYC's line of products, interior and exterior. They have an interior cleaner that works very well, leaves no residue, and doesn't turn everything glossy.
I spray some Armor-all on an old rag. Wipe it down. Then use a clean rag to get rid of any residue. Does a great job cleaning it and gets rid of anything you hands may have transferred onto the wheel, shines and protects it.
Reactions: Sauraus
Does it leave any residue? I really don’t want any slipping around on that wheel by my hands. ;)
As Tom said, no residue. I spray it on a terry cloth towel, and rub. Repeat several times with a clean section of towel until it comes away clean. Terry cloth works better than microfiber in this usage because it's got a little bit of abrasiveness that helps run off the layer of dirt.
Gonna depend on what the material you are trying to clean is...
Well, the OP's signature says he has a 2LT, so that means GM's coated leather.
  1. Good question! How do you guys clean the alcatera steering wheel? It gets funky after awhile. I try to use a soft wire brush every now and then to "fluff" the fibers back up. But it needs a deep cleaning... any ideas?
Thank you for the tip.... I will try this product out. I have seen Alcantara steering wheels that have never been cleaned and they are just gross to look at, let alone touch!
1 - 13 of 13 Posts
