1 - 20 of 101 Posts
The Corvette is engineered to leave nothing beyond your control. Expand the precision performance and incredible technology found in Corvette Stingray and Z06 Coupe or Convertible with the engineering excellence that goes into the Chevrolet Accessories designed expressly for Corvette.
Are these direct replacement because when I watched the video of the car being built, the front bumper cover badge was attached with ultrasonic welding?
Thanks
Alan
Discussion Starter #4
Yes, these are GM OEM replacements. The set are the exact emblems on the car, only in the carbon flash. The back side is covered in 3M tape.
Discussion Starter #6 (Edited)
Discussion Starter #7 (Edited)
Labor day weekend sale!!!!
Enjoy 5% discount over our entire catalog this weekend for Labor Day!
We have all your accessory, maintenance, and part needs.
Running 2 different sales this weekend.
Use promo code "LABORDAY" FOR A 5% on anything listed on our site!
Or if you have been debating on getting those WeatherTech mats before winter time comes, now is the time!
Use promo code "WTECH" FOR A $25 savings on any liner purchase.
Don't see the liners you want, contact us and we will be happy to help you out as well.
WeatherTech Floor Mats for Automobiles
Discussion Starter #10 (Edited)
Discussion Starter #11 (Edited)
Discussion Starter #12 (Edited)
Discussion Starter #13 (Edited)
Default Carbon Flash Lower Grille WITH CAMERAS for 2014-2016 Corvette C7 Z06 Z51
This is a Genuine GM Z06 grille painted from the factory in Carbon Flash from the 2015 2016 C7 Chevrolet Corvette Z06. This grille is supplied with the cameras mounted in the grille.
We offer the Z06 front brake duct kits and Z06 front license plate bracket, aero panel and retainers in separate listings.
Note: This grille fits all Stingray's without any modification.
Note: If you have a Stingray with the cameras these cameras will plug right in to your existing connectors.
Note: You are not yet able to add or retrofit the cameras to a vehicle that did not come with it from the factory.
2015 2016 C7 Corvette Genuine GM C7 Z06 Grille Carbon Flash With Front Cameras | Genuine GM | 23334750
Discussion Starter #14 (Edited)
New GM Front Spoiler Splitter Extension Kit 2015 Z06 C7 Z07 CFZ CFV
These are the larger winglets which attach to the outer edge of the front splitter. An aesthetic & performance appeal may be missing from your Corvette, and we can fix that for you! This kit comes in a carbon flash painted finish. This is not produced in carbon fiber. Why not, you ask? Because the carbon fiber could not hold the rigid cornersthis front splitter needed. So, rather than "cutting corners," GM produced the larger winglets in only a carbon flash finish that looks amazing!
WE have these in stock!
NEW GM FRONT SPOILER SPLITTER EXTENSION KIT 2015 Z06 C7 Z07 CFZ CFV - GM (23184895)
Discussion Starter #16 (Edited)
Discussion Starter #17 (Edited)
Clear Tail Light Lenses for C7 Corvette
Are you already tired of seeing the plain red tail light lenses that may have come with your Corvette?
This will help enhance the looks of your Corvette and really cause jaws to drop when they stare at that rear end driving away..
Some clear tail light lenses will do just the trick!!
These are NEW GM OEM tail lights that came as an option on the Corvettes.
NEW GM 2014 2015 2016 C7 CORVETTE STINGRAY LEFT & RIGHT CLEAR LENS TAIL LIGHT LAMP
Discussion Starter #18 (Edited)
GM Steering Wheel Options!!
2014-2016 C7 CORVETTE AUTOMATIC TRANSMISSION STEERING WHEEL OPTIONS
You can get these steering wheels in Black Leather or Black SuedeThen comes the stitching choice including (Black, Gray, Kalahari, Red, Yellow, Blue)
Also comes with no logo, competition logo, or a Z06 logo on the wheel as well.
And of course, Automatic or Manual
Just a reminder, we also have shift knobs and boots in leather or suede and the stitching to match
2014-2016 C7 CORVETTE MANUAL TRANSMISSION STEERING WHEEL OPTIONS
Here are some examples:
Discussion Starter #19 (Edited)
Z06 front brake rotor cooling ducts kit
Z06 FRONT BRAKE ROTOR COOLING DUCTS KIT
We made it easy for you with a kit including both left and right brake rotor cooling ducts
Z06 FRONT BRAKE ROTOR COOLING DUCTS KIT This is for a pair -- left, and right This is a great upgrade for improving cooling for those large 15" brakes some of you guys might be running on your C7 Corvette. These fit directly into the Z06 grille to use the air and force it through the car to use it to its advantage.
Discussion Starter #20
2014-2016 Corvette C7 Z51 Sway Bar Add On Upgrade Kit
Maybe you're not 100% satisfied with how well your base Stingray handles? That might be the cause of NO rear sway bar, and just a soft-ride(FE1) front sway bar. The solution is a set of front AND rear Z51 performance(FE6)/heavy duty(FE7) suspension sway bars.
This kit includes an upgraded front sway bar, and everything you need to add in a Z51 performance rear sway bar with the insulators and end links to match performance and handling to optimize the steering responsiveness and confidence in your C7 Corvette.
A C7 Corvette Z51 sway bar upgrade kit includes:
(1) 20966781 FRONT STABILIZER SHAFT (YELLOW)(CODE AAB5)(FE6,FE7)
(2) 22950841 INSULATOR (YELLOW)(FE6)
(4) 11546672 BOLT
(6) 11516078 NUT
(1) 22936510 REAR STABILIZER SHAFT (BLUE)(FE6,FE7)
(2) 22945601 END LINK (FE6,FE7)
(2) 22950837 INSULATOR (BLUE)(FE7)
(2) 20959449 CLAMP
(4) 11588742 BOLT
1 - 20 of 101 Posts
