How often do you use REV MATCH on your manual Transmission?
Thank you! I really appreciate your input.More info. I have been a powertrain engineer for 50 yrs, so I geek out on this stuff so bear with me.
I try to just present data so here goes.
The heal/toe is generally toe on the gas and heal of the same foot on the brake. The other foot is on the clutch. The reason is to make smooth downshifts, save the clutch disk and keep the tires from breaking traction. The Auto Rev Match replaces the “toe” part of this work.
With the Auto Rev Match on.
This all works with a lot of magic going on. Down in the trany/shifter are a few sensors. These tell the computer what gear you just came out of and what gear you are going into. It senses when you come out of gear gate to neutral and when you move the shifter to the new shift gate area. If you shift slow you can hear two engine blips one for coming out of the gear and one when you start to put it into a gate/gear. This info is sent to the engine computer.
Next the real work starts. The engine knows eng speed, vehicle speed, gear out and gear in rotation. It also controls TB position, valve timing, fuel. It has a number of look up tables it goes to for a number of other parameters, torque and misc others. So when down-shifted quickly it takes the engine speed to the proper rpm for that gear/vehicle condition. It does that using these other measured and controlled eng parameters. So the eng rev is not just a blip but a very well calculated eng condition to make the best match for all the parameters. If shifting slow then it may sound like just a blip.
I pulled up my Z06 gear charts. A typical downshift I do is a 4th to 3rd gear shift with hard braking. I target about 3000RPM . This is no more than a 500 rpm mis match in engine speed. My downshifts take about .2 sec or less. This is about 10 engine revolutions. So with the use of Auto Rev Match the engine might see as many as 10 revolutions during the shift and likely fewer. And the speed of the engine is in the band where it is meant to produce the correct power (timing& fuel are all adjusted properly). These calculations happen between 50 and 400 times a second. The engine is not over revving or over working it is controlled to the speed it needs to be. It is in its happy spot for that shift.
Now if one does not use rev matching or a toe blip, the clutch & synchro must take the hit for these engine rotations until the 500rpm mis match in speed becomes close enough to stop clutch slipping. This generates heat in the clutch, extra wear on the synchronizers, and sometimes a bit of gear clunk. One way or the other the engine speed must match the vehicle speed conditions.
If shifting slowly the computer can not predict just how slow or fast you push the gear selector into the final position so it may have the eng revs drop off slower than desired- sometimes called engine hang. This is what many don’t like about the Auto Rev Match.
I hope this might shed a bit of light on the matter.
Ok and now double clutching: For up shifting or down shifting. There are a few different names for this and a few methods but in general the following is the general idea.
This method is used with older manual tranys that did not have synchros or the synchros were not very good. So what a synchro does is synchronize the speed of the input gear to the speed of the output gear it needs to engage with. Gear teeth have to match or they grind very badly. So, if you just pushed in the clutch and shifted up a gear, one of the gears was not turning the proper number of revs. So, an angled ring is placed on the gear shaft to slip into the gear to help bring it up to speed so as not to grind the gears this piece is the synchro. If this was not present or not working good enough when you shifted then you needed to do something to get the speed of the two gears turning the correct speed to mesh. After pushing in the clutch and moving the shifter, you let the clutch out so the gears had a chance to spin the other gear up a bit then push the clutch back in a bit and then let it out again to bring the gear speeds together. Between the two clutch engagements you blipped the gas as necessary to help match the gear speeds. So, you used the clutch twice to make a shift. Watch the Bullitt chase. Bullitt does some downshifting in the hills and upshifting in the final chase.
I hope this helps.
