Usually reading and following a label's advice is a good thing. Maybe not this time!
The oil filter sticker is wrong on some 2014 Corvette StingRay factory-installed oil filters, i.e., the wrong label has been installed on the correct oil filter. No word yet has many oil filters are out there with the wrong sticker. This is a picture of the wrong sticker on the correct filter.
A PF63 oil filter is longer than the PF 64, and while its' use will not cause the motor direct harm, because it is longer, it could, under full suspension compression, hit the suspension and cause the oil filter to be at least be compressed, possibly be so damaged as to start leaking oil. Secondary consequences of this would not be pretty.
So imagine a person, and we know there are Corvette owners out there (like me), who decide to do a supplemental, say at 1,000 miles, "extra" oil and filter change, to remove some of the tiny metal filings from break in, and that person reads the label, buys a PF63 filter and installs it. OR, how about a dealership tech, who has never seen a StingRay before, at customer direction changes the oil and filter and, again reading/following the label, installs at PF63 filter. Here is the correct filter with the correct label.
Article/picture source: GM TechLink, "The PF63 filter will fit the engine. However, it is significantly longer and it is possible it could be damaged if the suspension goes to full compression." Needless to say GM is warning its dealer technicians through this link: Oil Filter with Incorrect Label
