1 - 5 of 5 Posts
This may be the wrong forum, but I'm trying to find the drains on the drivers side in the engine area. Do I have to remove something? I found the passenger side drain easily.
Maybe you are confusing folks... I know I am...confused. There are drains in the engine bay? So where is the passenger side version?
it's kind of behind the battery. It's a small area to reach into, but hangs down and you can empty the rubber "drain" by opening the bottom to let debris out.
Now I am confused since the battery is in the back inside the car. Are you talking about a C7? Because that's where you posted.
There isn't any battery in the front engine compartment of a C7. Your post looking for drains was in the C7 area. Are you meaning a C8?
1 - 5 of 5 Posts
