When I got my 2015 Stingray out this year, I had a couple of electrical issues. All winter it was on a battery tender, so no problem with the battery.
When I stop my engine and open the door, the driver's window will drop down (index), but then come back up while the door is still open. Because of this, I need to lower the window manually to keep the glass from hitting the trim. Also, the radio does not turn off when I open the door (still turns off after 10 minutes or so, so no real problem).
Today, I disconnected the battery for 20 minutes, the reconnected. I went in and reset all of my electrical options, but the window still goes back up while the door is open.
Anyone else with this problem, or any suggested fixes (other than disconnect the battery)?
Thanks
Thanks
