1 - 8 of 8 Posts
Last night after eating out would not initially power up. Then after several tries got the open driver window and reclose message. Then got the open passenger window and reclose message. Finally started and died as pulling out of parking space. Doors at this point are locked as designed because is not in park and got repeat of window messages. Restarted and drove 25 miles. OBD light came on and stayed on. Next morning saw that window had not gone down to allow door to properly close. Went through window opening and closing drill and got it powered back up. Going to dealer tomorrow if I can get started and will get back with verdict. (It only has 950 miles. Purchased in April.)
Glad it was found by your dealership and you are back "happy motoring." Thanks for letting us know the resolution, so if others have a similar problem, they have another specific option to check.
Dealer found loose 100 amp fuze block.
So pushing the fuse in would not help because the block was loose. Is the block screwed in with regular Phillips head screws or something different?
1 - 8 of 8 Posts
