Add tow hook ?
8.2K views 21 replies 13 participants last post by  Stoan
#1 ·
2017 Stingray 3LT
Previous owner apparently bought a tow hook not knowing there isn't a receiver for it. Is it possible to add one ?
#2 ·
owns 2018 Corvette C7 2LT
#4 ·
Early on I bought one for my 2016 Z06 from my dealer. About $70. Never have had to use it. --Bob
#6 ·
Here is a quick shot of my 2019 1LT, showing the receiver behind the grill on the right side.
I purchased a previously owned tow hook from someone on one of the forums, went to try and fit it, and looked like the grill would be damaged if I tried, so it is in the cubby in the back just in case some sort of emergency occurs and I need to chance sacrificing the grill.
#13 ·
The grill section where the receiver opening is snaps on and off but because that that hole opening is covered makes me ask the question what year is your car as 2014’s early 2015’s didn’t have the front tow hook receiver. Z51 added the tow hook receivers during the 2015 MY on about the 12-1-14 production date.
This is what it should look like compared to what yours looks like unless the cover pops out?
Does this show the cover you talk about ? How do you access it to remove ? It looks like the grill is in the way. Excuse the bugs, just got back from a trip. :D View attachment 284340
#8 ·
One of my old post:
If I recall correctly 2014’s early 2015’s didn’t have the front tow hook receiver. Z51 added the tow hook receivers during the 2015 MY on about the 12-1-14 production date. I’m sure you will come across the exact yr/date I’m referencing or I’m sure someone would verify or correct my recollection.
If you have the receiver (Z51's/Z06/GS), you must purchase the hook from GM. Doesn't come with the car. Take a look at the foam cover over your battery which is the place for the hook, but no hook so you have to purchase one.
#9 ·
I also will add that Corvette receivers are needed for C7 models built before 12/14/14 that lack a receiver slot from factory.
Here is a thread on how you retro-fit for those early models that didn't have the receivers.
Base Model Tow Hook receivers front/back installation
#15 ·
So, looking at the picture there appear to be two tabs. If the tabs are at the top I would try pushing up with my fingers and then pulling outwards to remove it.
So how does that section come out of the grill? push it back and turn it sideways?
I looked at mine looks like it is removable but when I tried to gently push on it it did not budget.
#17 ·
Neither my 2014 nor my 2018 C7s have tow hook receivers. Unless you are planning on racing your C7 on a sanctioned track that requires a tow hook and/or you only want it for appearance purposes you might want to forget about adding the necessary receivers, etc. If you search us out Search Community function at the top of every page, you will find a lot of posts regarding tow hooks (or the lack of). Many commercial tow truck companies will NOT use a tow hook you have added because of their liability.
