Status
Not open for further replies.
Some issues I am seeing - 12/13/13- 11/19/14
104K views 280 replies 76 participants last post by  Chip
#1 · (Edited)
I like to check our forum and other vette websites just to see what sort of trends I can find. I am seeing a couple of issues that have had more than a single occurrence. I am throwing them up here so that if anyone here has the same issue we can have it posted in our “issues & resolution” forum. I have spotted a couple of issues that are worrisome.
Base and Z-51 cars are still experiencing problems that require a rear diff replacement. I cannot tell if the cars affected were only those early low VIN cars with low lube or not? From what I’ve read the lack of proper lube level can kill a diff. pretty quickly.
Another issue that I am starting to see is that several owners of manual tranny equipped cars are reporting that their shifter moves hard into neutral as the tranny kicks out of gear. I have not seen follow ups on these reports and will see what happens and follow up here.
Lastly, there seems to be more issues with the infotainment screen going blank. A new owner of a convertible owner has reported issues with his doing this.
#260 · (Edited)
Heads Up- Important info.!
This may well be as a result of possible oil starvation issues some of our forum owners have experienced which lead to engine failures. If I find out that this become a TSB it will be posted in the TSB / Recall thread.
"Engine Repair with Crankshaft Replacement
If the crankshaft (Fig. 21) needs to be replaced on 2014-2015 Corvette, Silverado, Sierra; 2015 Tahoe, Suburban, Yukon/XL and Escalade models equipped with the 4.3L, 5.3L or 6.2L engine (RPOs L83, L86, LT1, LV3), be sure to follow these guidelines before completing a crankshaft replacement:
• Complete all appropriate Service Information diagnostics to determine that the crankshaft requires replacement.
• If the engine has bearing and crankshaft damage, the engine should be replaced along with the oil cooler.
• On dry sump engines, the oil tank and lines should also be replaced with the engine.
• Follow the latest version of Bulletin #09-06-04-026G to verify that the ECM calibration is not an aftermarket calibration.
• If a Corvette owner prefers to keep the original numbers matching with the engine, call TAC for repair directions."
#262 ·
When I pulled into my garage and applied the main break pedal my Instrument Cluster and Infotainnment screens both went dark although the engine was still running. Later I started the car with dark screens and the screens came back on when I backed over the small bump from my driveway to the street. Anyone else have this problem? A lose connection perhaps? My C7 has 87 miles on it. It is a little spooky to read of all the C7 problems on this forum, to be sure.
#263 ·
I had a similar problem recently. The dealership re-flashed that system and all has been well every since.
Save
#269 · (Edited)
Less that 1000 miles and trans problem!
That picture made me glad to have purchased another C6 Z51 Vert private sale (after selling my 05 for a C7).. I will drive the C6 while I wait for the 2016 Mazda MX5 to come out next year.:cool:
I have lost confidence in GM or the C7. Waaay too much money to see this many usual issues on a $70,000 car. I just want a reliable two seat roadster. Doesn't have to be a Corvette. Yes I know all cars have issues but GM service is overwhelmed with recalls and issues and people are without their cars for months. IT's a shame. I love my C6. I like the C7 Convertible but I think it need a few years to mature.
#267 ·
That picture would be perfect for a GMPP advertisement. Exposure to all these stories has caused me to commit to buying a GMPP plan for my new C7 due to arrive next month.
Save
#273 ·
Sorry that getting you car fixed has been such a long process, and that it has a way to go. Glad you are getting a brand new roof assembly. Here's to that being the perfect and final solution!
#274 ·
Just had my 2LT Z51 serviced @ 6500 miles. My steering wheel leather was separating, there was a huge bubble under the leather in center of the console and weather strip torn at rear of removable top (body side). The dealer ordered me a new steering wheel, console and weatherstrip. Other than those items, the car was fine.
Reactions: U.S. Marine
Save
#277 · (Edited)
Tony; I have my eyes peeled to see if there is a TSB on this issue or not. I thought I found one several months ago, but I am not able to locate it again on any of the sites I use to find such things. Be assured, if and when I find it, it will be put it up. On the other hand if you find that there is one that your car is repaired under be sure to let me / us know. I got the impression that the owners I quoted were taken care of by there dealers without a lot of resistance. I don't understand why you are having this problem and why no one has been able to fix it?
#278 ·
Fuel injector and Oil Ring Seal Replacement
I just came across this and am posting it as a heads up. No preliminary or TS bulletins on this condition yet as far as I can tell, but that might change.
Fuel Injector and Oil Ring Seal Replacement
"If Service Information diagnostics indicates a fuel injector may need to be removed for a repair or replaced, such as for a fuel odor or extended cranking condition, on a 2014-2015 Corvette, Silverado, Suburban, Tahoe, Sierra, Yukon, or Yukon XL equipped with the 4.3L engine (RPO LV3), 5.3L engine (RPO L83) or 6.2 engine (RPOs L86, LT1, LT4), be sure a new O-ring seal is installed…"
#279 ·
Chip, I THINK I remember seeing someone post that their car is stinking like fuel fumes. I wonder if they have this problem. Let me see if I can find that post...
Save
Status
You have insufficient privileges to reply here.
