I wanted to do a quick recap of my experience of having a Z06 Supercharger installed on my 2015 Z51 Stingray.
I bought the used and already ported LT4 supercharger "complete kit" (Blower, Heat Exchanger and Water pump, LT1 to LT4 adapter plates, Z06 balancer, Z06 tensioners) from a forum member who bought it from a Z06 owner who had a Procharger installed. The used blower was from a 2016 Z06 with 900 miles on it at the time of take off.
I took the car down to Weapon X Motorsports in Cincinnati, OH. They do so much work with C7 Corvettes, 6th Gen Camaros, and other LS type engines, it made sense to have them do the install. I was right! It was an awesome experience all throughout the entire process.
Here are some pictures taken during the install.
One of the main reasons I chose to go this route (vs. Procharger or Edelbrock) was to make it look as factory as possible...and I believe it does!
I wanted to change the wording on top of the supercharger to something other than "LT4 Corvette" So I contacted Emblempros.com and had custom cover plates made!!
Although I bought a "complete kit" that included the following parts....
1.) LT4 Blower,
2.) Heat Exchanger, Water pump and Reservoir
3.) LT1 to LT4 adapter plates
4.) Z06 balancer
5.) Z06 tensioners
The install needed a bunch more parts and accessories to complete the install...For all those contemplating going this route....Here are all the items that had to be purchased to make the install complete:
1.) Z06 air intake. I decided to go with a Halltech intake.
2.) New Brisk Sparkplugs
3.) LT4 MAP sensor
4.) Custom LT1 to LT4 MAP and IAT Sensor adapter harness
5.) Gates Supercharger drive belt
6.) Various fittings and bolts.
7.) Coolant for Heat Exchanger
8.) Rubber hoses for adapting to new PCV system
9.) Custom 12V relay and wiring harness for Z06 intercooler pump
10.) Supercharger oil
11.) Modified LT4 Valley Plate
The stock fuel system was not quite enough so....
12.) Z06 Fuel injectors
13.) Z06 High Pressure Fuel Pump
Final before and after Dyno numbers are quite impressive!!!
610 Tq / 570 Hp at the wheel! or around 732 Tq / 684 Hp at the crank
The car drives fantastic and has amazing power down low...It is a different car! I love it!!!
The total cost was very similar to having an Edelbrock Eforce installed....with far more power and a totally stock look!
All in all, I am very happy! Ben, Blake, and Jeremy from Weapon X Motorsports are fantastic!! I am sure I will be back down there for more upgrades later in the year....
-M
1.) LT4 Blower,
4.) Z06 balancer
5.) Z06 tensioners
3.) LT4 MAP sensor
-M
